Syncmaster 22" 226BW no image....help
12 Aug 2009
Swindon
Hi all.
Ok straight to it.
I have the above monitor & basically I got in this evening put my pc on...fine.
Kicked off AVG to check updates (been out of country for a few days) then went upstairs to bath both of my kids.
When I came down the pc was running but the power light (blue) was flashing with no picture. Ok no worries I'll just move the mouse/hit a key like normal to come out of power save.
Only this time nothing happened. I tried rebooting many times. Initially the light comes on, top corner shows an animation of either analog or digital. It can't do either then flicks to an animation of red/green/blue square with the message 'check signal cable' & analog below. This moves around the screen with nothing happening.
I've checked all cables & gone through all the trouble shooting options here
http://downloadcenter.samsung.com/content/UM/200709/20070917140652875_BN59-00521H-03Eng.pdf
to no avail.
Has anyone got suggestions I could try.
I haven't tried other cables yet... Will have to purchase them first but a bit reluctant to splash out if something silly.
Many thanks in advance
Heffers
Of course...
I think my tv will accept the cables, will let you know.
A friend thinks it might be one of my old 8800's I have in sli
Update & closure.
It would appear my primary 8800 has blown.
I've put the secondary 8800 in & hey presto I have a working pc.
Unfortunately I have no SLI now boo hiss
