11 Dec 2020 at 07:44 #1 Gimpymoo Gimpymoo Soldato Joined 31 May 2005 Posts 15,654 Location Nottingham Any modern alternatives? Do not need internect connectivty, just for cloning changes across local network. Thank you.
12 Dec 2020 at 20:08 #2 MarcLister MarcLister Soldato Joined 7 Mar 2005 Posts 19,705 Location LU7 Are you looking for something with a GUI? If you don't need a GUI use Robocopy. If you want a GUI use Robocopy and then a front-end: https://www.howtogeek.com/130729/ad...-to-the-microsoft-robocopy-command-line-tool/
15 Dec 2020 at 14:11 #4 Frosty81 Frosty81 Associate Joined 3 May 2007 Posts 53 I've used a scheduled task with freefilesync for the past few years without issue
7 Mar 2021 at 17:48 #5 LaurenBlake LaurenBlake Associate Joined 20 Feb 2020 Posts 9 I use Gs Richcopy360, very robust to copy over WANs , over LANs and to clouds , and I second recommend GoodSync as the best alternative.
