You also need to specify the name of a folder pair, eg: SyncToyCmd -R "My Backup"..."...path/SyncToyCmd.exe" -R
yes pass is set correctly
The cmd prompt window flashes up briefly at the scheduled time, but so quick i can't see the message it displays
Click on "expert" options in the profile setup, then it's "Compare Options" > "Skip the Differences screen when this profile is run." Also, you could look in "Decisions - Files" and make sure all the "prompt me" tickboxes are unchecked.SyncBackSE worked wonders, thanks,
Do you know how to turn off the prompts that ask what to do when a file has changed.
