Synology Data Replicator 3
12 Sep 2003
Newcastle, UK
Hi all
Is there a way to set the Data Replicator to choose "sync" automatically, each time the app starts with Windows?
At the minute you have 20s to choose whether to go into sync mode or whether to do a backup first, then go to sync mode. If you don't choose it will do a backup first.
This is a bit annoying as it means when I turn the PC on, I have to wait and select the option to just sync. I sometimes forget, and come back into the room and it's starting to do a full backup to the NAS. Grr! :p
I just want it to startup and go straight into monitoring the selected folders/files.
Can it be done? :)
Thanks!
I couldn't get on with data replicator. I use microsoft synctoy, a free power tool, only downside is its manual. though im sure it could be set to autorun
