Synology DS212+ Or Similar Sabnzbd and Sickbeard
18 Jan 2008
Fleet
Hi, Has anyone got an Synology DS212+ Or Similar NAS just wondered how well it works and if there are any limitations you have found with the Synology NAS in regards to running Sabnzbd and Sickbeard. I.e unraring etc.
I'm replacing my Win Server to cut down on power bills and plan on using this NAS to Stream to WDTV's/Squeezebox and download content etc.
Thanks
I have the ds210j, and it works great - not had any issues with running sabnzbd, unraring is absolutely fine. As a NAS and streaming solution, i'd highly recommend it. fwiw, mine is streaming to a jailbroken appletv2 with XBMC on it, lovely front end, nice remote :)
If all you'll be doing is downloading, storing and (light) streaming then the Synology will be fine. Only issue you'll have is if you need to transcode video which is basically a no go on a DS212 and out of the 2, the HP will be better suited to this (although power consumption is roughly double on the HP).
