Hi,
I bought myself a NAS and have run into issues straight away that I cannot find an answer to on the Synology website.
Step 1: Installed HDD, plugged into router, turned on, go to find.synology.com and I get this below
Excellent it finds the NAS.
Step 2a: Click connect, doesn't connect
Step 2b: I have downloaded the latest Synology Assistant from their website and as an alternative setup it should find my DS215j and I can set it up that way. It doesn't even find it on the network via the SA software
I have little network knowledge but if anyone could suggest a few things for me to try that'd be great, thank you.
