Synology not making use of gigabit fibre
Caporegime
9 May 2004
Leafy outskirts of London
I have a DS215j hooked up to my Hyperoptic Hyperhub with a cat5e cable.
When I plug the same cable in to my laptop and do a speedtest, I get over 600Mbps.
But when I hook up my Synology and run Download Station, I seem to max the line out at around 10MB/s (or 80ish Mbps).
The NAS has a gigabit lan, the network is showing that it is gigabit too, and I know the cable can do more as my laptop does.
I've checked all the settings on he Hyperhub and in DSM and I can't see anything that would be limiting speeds/bandwidth.
Any ideas?
Download Station as in torrents? The 215j has an anaemic processor, I wouldn't be surprised if it was maxed out doing 10MB of Torrent/NNTP traffic.
Cpu's only sitting at 50%, oh well, it's not the end of the world as it's a 24/7 device.
If the switch/device are showing 1gbit negotiated then the constraint will most likely be the device.. not surprised really.
CPU Model MARVELL Armada 375 88F6720
CPU Frequency Dual Core 800 MHz
System Memory 512 MB DDR3
Limit the amount of connections per torrent to 15.
