Hi all,
Trying to build a sysprep file, and having a few problems with it, I have set the activation proxy in it, however it does not seem to be working, when it auto logson it says there is a problem with the licence and needs to activate it, then will eventually prompt for the proxy box, enter that and it will all work, however I believe this should be done all automatically, anyone suggest what is not working correctly?
Unless someone knows the domain/IP that XP talks to for activation and I can set up routing on our network for it.
Thanks
Kimbie
************ = Company identifying marks,
Thanks
Kimbie
Code:
;SetupMgrTag
[Unattended]
OemSkipEula=Yes
InstallFilesPath=C:\sysprep\i386
Autoactivate=Yes
AutoactivateProxy=Proxy
TargetPath=\WINDOWS
ActivateProxy=Proxy
[GuiUnattended]
AdminPassword="************"
EncryptedAdminPassword=NO
OEMSkipRegional=1
TimeZone=85
OemSkipWelcome=1
AutoLogon=Yes
AutoLogonCount=2
[UserData]
FullName="************"
OrgName="************"
ComputerName=103till5
[Display]
Xresolution=1024
YResolution=768
[TapiLocation]
CountryCode=44
AreaCode=01733
[RegionalSettings]
SystemLocale=00000809
UserLocale=00000809
InputLocale=0809:00000809
[Identification]
JoinWorkgroup=************
[Networking]
InstallDefaultComponents=Yes
[Proxy]
Proxy_Enable=1
Use_Same_Proxy=1
HTTP_Proxy_Server=activation.************.co.uk:8000
Proxy_Override=<local>
[Branding]
BrandIEUsingUnattended=Yes
[GuiRunOnce]
Command0=c:\inst\run.bat
