System benchmarks - advice, clocks, cooling & upgrade help
10 Apr 2012
Basically, I've benchmarked my entire PC recently (if there are any components I can bench that I haven't let me know!). I was wondering:
1. What should my next upgrade be?
2. What can my CPU clock to on the stock cooler?
3. Is it worth aftermarket cooling for higher clocks?
RAM:
2x 4GB Kingston HyperX Genesis 1666mhz DDr3
CPU:
Intel i5-3570k @ 3.4Ghz (stock)
GPU:
HIS HD 7950 3072MB GDDR5 (Overclocked, Core 1000 / Memory 1525)
HDD:
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB
Motherboard: MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3
PSU: OCZ ZS Series 650W '80 Plus Bronze'
Thank you for your time. :)
Which one of those is the best overall for quietness and cooling efficiency?
I am getting sick of the stock cooler whining like a baby lamb tbf. :p
Cheers. :)
What case do you have and what is your budget?
Antec 300 Three Hundred Ultimate Gaming Case, it's bloody huge, but could only just fit the G43 and the 7950 in it. :/ Do cases get any bigger? Actually, does any hardware get any bigger!? I'll need a new house if they do haha. :p
Don't have a budget yet, need to get abit more money together after my last upgrade yesterday, looking for upgrade and overclocking advice for the future. :)
I would recommend getting an SSD if you are looking for just basically getting a better load time, I would not live without an SSD in my computer. Samsung are epic:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-162-SA
Next on the list. ;)
I would go with a liquid cooler the intel one is suppose to be quite good:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-IN&groupid=701&catid=2330&subcat=2345
Stelly
What is watercooling essentially? Can it leak? Cheers!
