I was fooling around with the computer, and read somewhere that the voltage for my ram would be better at 2.0 volts instead of 1.8, so I did. now system won't boot :S
bios starts up, kind of, but won't go past the first screen. If i press Tab for the message, it says that there was a system boot failiure and i should reset the settings by pressing delete. But at taht stage, if I press delete, nothing happens. If i press delete soon as i reach the first image screen so I can get into settings, then it starts to do it, but hten reaches a black screen and stays there. I just tried updating the bios through EZ flash, and that went off fine, but the problem is still there. I'm at kind of a loss right now :s any help would be greatly appreciated. Would resetting bios with removing the battery and ressting jumpers etc. help at all?
motherboard is P5N32 SLI Premium
and ram is 2gb Corsair C4 6400
processor is x6800
processor is x6800
switched taht around and its working now.
