System booting straight into BIOS
3 May 2004
Hi,
I just changed my mouse to the new Logitech G400 and since then whenever my system boot it goes straight into the EFI BIOS.
Nothing else changed but the mouse.
Motherboard is MSI P67A-GD53
I had the exact same issue when I left my ipod connected at boot.
Removing it fixed this.
Quick update, found that removing the USB cable from the system > monitor (monitor has a few USB ports on the side) now fixes this.
Annoyingly I use the usb ports on the monitor a lot.
Any ideas for a better fix?
maybe it sees the memory card on mouse(if it has one) as a memorystick and not a mouse.......try making sure your 1st boot device is your primary driver.
