Hi,
You guys were great last time. I needed to spec a build for a friend, he has a budget around £300 to £400 if it is possible and the PC is mostly used for playing Battlegrounds.
He needs a case and probably PCI wifi I suspect too.
Could you give some guidance?
Cheers!
Cheers!
