System Build Advice Please
Caporegime
25 Jul 2003
FR+UK
Its been ages since I water cooled, and this would be my second setup, so far from experienced. Just wondering what the more experienced WCoolers on the forum would advise.
Hardware:
Intel Core 2 DUO E6600
Asus P5N32-E PLUS
Antec Nine Hundred Ultimate Gaming case
BFG GeForce 8800 GTX OC 768MB (Will possibly be adding one later)
Enermax Galaxy 850W
Team Xtreem 2GB (2 x 1GB) DDR2 PC2-6400C3 800MHz
Now, firstly I'm not bothered about overclocking to the extreme, but I would like to do it somewhat, would air be sufficient cooling?
Secondly, I am expecting the graphics card fan to be pretty noisy, and if I were to buy a second, its only going to get more noisy, in addition to this SLi with two cards like this must chuck out a horrendous amount of heat, I know the case has good reviews in terms of airflow/cooling, but taking account of the fact that I might wait until the next gen nvidia cards to go SLi, I might not need Water.
Er, other things..Not really able to mod the case much simply because I don't have any tools, but should I be able to find some, recommended mods to improve cooling/reduce noise are welcome.
And lastly to the WCoolers, what kind of gear would you recommend (would need to cool cpu, and possibly 2xGpu) :)
TIA
Edit: Also had questions regarding adding gear, and moving. Obviously I'll need to drain the system if I added a gpu block, any tips on doing that as I've never done it? And if I move house (renting atm so likely in ~6 months or whenever), how easy is it to do this, I presume draining and packing etc can be quite difficult?
