Hi everyone,
I've just finished building my system however I need some advice with my fan configuration to ensure I've made the right decision. I've got a corsair 400C case and within this I have 2 x Corsair AF 140mm fans as intakes above I have the Corsair H100i V2 exhausting out of the case and finally a single Corsair AF 120mm also as exhaust.
I did some research beforehand and this seemed to be a configuration a number of people had in their cases. I've seen the Corsair H115 mounted on the front in a push-pull configuration with 2 x 140mm exhausting and a single 120mm exhausting out the back but this would have cost more than I had to do at the time. Do you think my current fan configuration is a good choice?
Thanks in advance.
Thanks in advance.
