Hi All
So, I've got a great big coolmaster http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212x/ which I was going to use on my AMD, but can't because of screw problems.
So I'm going to build a whole system instead. It's the sensible thing to do. What I want is a desktop which will
Parts will most likely be ordered new year/boxing day. Motivation for upgrade is that Inquisition is killing my CPU, but my graphics card is only running at 50%. Current CPU is an AMD 945 phenom 2.
Oh, and I've promised the wife that if I don't upgrade by the end of January I'll stop thinking about it till next year. Been thinking about upgrading for months, and she's getting tired of it. (She probably means till 2017, not next year, but I didn't check...)
Edit to add: I have a couple of SSDs I can use for this - no need for drives.
- Fit and use the coolmaster 212 - it's a bit big, so case size is important
- Re-use my current graphics card (7850), which will be replaced next generation
- Be Quiet (sound proofing in case welcome?)
- Cost no more than £400, ex VAT. (Slightly soft limit, would consider shifting up for good reasons)
- Not be wasteful. We all know that it's possible to waste money on a bleeding edge chip, when dropping it 2 models will save you 1/3 the cost, while reducing performance by 4%. I don't want to wince at the wasted £100 every time I boot it because I went bleeding edge.
- It must last. Will be the last upgrade I do for, well, a long time.
