system build help
16 Apr 2014
Need a little help with my new system build, mainly will the psu be fine to power all.
EVGA GeForce GTX 780Ti Superclock 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2883-KR)
Cooler Master Cosmos II Ultra Tower Case - Black
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor
Asus Z87 SABERTOOTH Intel Z87 (Socket 1150) DDR3 ATX
Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic
Noctua NH-D15 Dual Radiator Quiet CPU Cooler with two NH-A15 Fans
Corsair AX750 Professional Series 750W AX ATX/EPS Fully Modular 80 PLUS Gold PSU
2 of Western Digital 2TB SATA 6Gbps Power Saving Internal Hard Drive OEM - Caviar Green
OCZ AGT3-25SAT3-240G Agility 3 240GB SATA III 2.5 inch SSD
Sony AD-7280S-0B 24x Internal SATA DVD Multi Writer Black Bare
Corsair CMZ8GX3M2A1600C9 8GB 1600MHz CL9 DDR3 Vengeance Memory Two Module Kit
Thanks for all your help
budgets only small i already own most of the stuff from my last build which is Z68 running a gtx560ti. Rig is for occasional gaming and a bit of graphic design, basically anything i throw at it i want it to be able to cope with. I have two monitors both Asus VG248QE not really fussed about the colour scheme what i want to know most will the psu power it all or do i need a bigger one. Thanks
There may lie your issue,
What cooler are you currently using?
If that RAM is the High profile stuff (like this) the cooler will be obstructed by the RAM.
I suggest you get a different cooler, a H80i would be ideal..
YOUR BASKET
1 x Corsair Hydro H80i High Performance Liquid CPU Cooler £74.99
Total : £74.99 (includes shipping : ).
at the minute i use Arctic Cooling Freezer 7 Pro Rev.2 CPU Cooler is there any other way of doing it because i dont want to use watercooling
