System Build Service from OCUK?
3 Jan 2008
Hi,
Do OCUK offer a custom build facility?
So I could pick specific components and get it built?
I have built a few PC's myself and was quite competent at it in the 90's, but then CPU paste started getting involved and it put me off :)
Basically I'm looking for a low noise i5/i7 CPU with 128GB SSD, 2TB storage, 8GB memory. Nothing amazing really, something that will power through MS Office, and play a bit of Starcraft 2 / WoW.
I like the look of this one, but there is no mention of low noise.
http://www.overclockers.co.uk/showproduct.php?prodid=FS-322-OK&groupid=43&catid=2476&subcat=2563
Cpu coolers come with the paste already applied, so no mess there :D If you stick with the stock Intel one it just clicks into the board with 4 pegs.
If you wanted a prebuilt one you can speak to customer services and make any changes you wanted. I would also get one of the Superflower power supplies, as the one in your post is pretty naff (OCUK power supply) :D
Where you based? if a members based near you, im pretty sure with some kind words and encouragement you can probably someone to come round and show you how to build it :)
Save a bit of cash that way too and can pick the bits you want
