Hey all,
I was initially planning to spend an additional £100 or so, but I've had to limit my budget due to a general lack of cash, as the other stuff I needed to buy for starting university cost more than I expected it to!
If you people could check out this system build and confirm that it is all compatible I would appreciate it, whilst any last minute recommended amendments are also welcome:
CPU: AMD Athlon 64 X2 3800+ AM2 (~£94)
Mobo: Gigabyte GA M55Plus-S3G (~£58)
RAM: 1GB Corsair Value Select, DDR2 PC5300 (~£60)
HDD: Western Digital Caviar SE 250GB 16MB (~£52)
PSU: Sansun Arctic 500w Modular (~£35)
Case: NZXT Trinity Silver (~£39)
SPU: TRUST 5.1 SOUND EXPERT OPTICAL (~£16)
DVD: LG GSA-H10NBAL 16x16DVD±RW (~£25)
LCD: HANNS G HW191D 19" (~£130)
Keyboard: Wired Zippy WK-9000 (~£8)
Mouse: MLK 10 Button Wireless Optical Mouse (~£7)
TOTAL: ~£524 (Plus any P&P costs)
I'll then have to buy a tuner card and printer with anything left up to £600 and will probably then buy some speakers separately, as I was going to buy a cheap hifi system to take with me anyway.
Upgrade paths:
1) An additional 1GB of DDR2 RAM.
2) A graphics card, come christmas I think the likes of the 7900 will have come down a lot, allowing them to be a realistic consideration for a poor student.
3) Additional SATAII HDD, probably 250-300GB once more, I'll probably consider this when I hit 200GB used space.
4) Maybe a soundcard, however I will consider putting the trust 5.1 into my current system and moving my audigy 2 ZS into my "University system" for the added sound quality.
Thanks in advance for any advice or help on this matter. I'll probably be ordering the components in a few hours, so just need the compatibility of these parts confirmed.
Kind Regards
John
Upgrade paths:
Kind Regards
John
