Just a quick question about max memory setting in boot advanced opitions do i have it ticked or not if yes at what amount set to. it will only go to 4000 i have 6 gig of ram
What version of Windows are you using? I am assuming Vista or 7 64bit. If it goes back to normal when you're done, then there is nothing to be concerned about.
If you open up the Task Manager, then Performance tab, then click Resource Monitor, then click on Memory, you get a nice little chart showing you how your memory is being used.
Green and Orange sections are RAM being used by running programs. Dark blue is cached items and light blue is free RAM. Cached stuff is always cleared away to make room for running programs, so don't worry if this take up most of whats left of your RAM
