System Configuration- Fans
18 May 2012
When I create a PC in the System Configuration section , specifically the extreme gaming section, where it lists all of my selected components to the right it also shows I have a "Sharkoon 120mm 2000RPM fan".
Does this come with the bundle? Why can I not change it?
I know the answer is probably obvious but I just dont know anything about it.
Thanks
You need to list what components you have ordered, there are a lot of options.
Maybe its an add on, dont worry if your happy with spec/cost.
syscon_int.php
The said fan is always the same despite changing any of the specs.
