System Configurator
25 Dec 2013
Hey,
So after going without luxuries like food and drink for a few months I will finally have enough to get a beast rig in a few weeks.
Just had a couple of questions about the System Configurator and store options.
So, first of all, I would like to get 32 gigs of ram to speed up the editing work i will do but I can only see options for 16 gigs max. I also would not mind having more than 2 HDDs.
Is there any way to actually add them to the build? Sure, rams are easy to put in and i could probably manage to install the hdds without blowing up the rig but it would still be nice to just have them installed already.
The other thing was warranty. I see no warranty options in the system builder, so i would like to know what is actually offered. Also, is the warranty affected by the parts that are overclocked by you before shipping?
The warrenty on all OcUK pre builts is 24 months, as your needs it maybe better for you to buy parts and get exactly what you need and you normally get more warrenty but your your have to build it and overclock it yourself.
