Okay, my PC did have some freezing problems around 3 weeks ago (would freeze for a second and then be fine), which i thought were related to me messing with RAM voltages, but after resetting the BIOS and reloading the correct settings the PC has been fine since (has been on for 5 days solid with no issues until tonight).
I was almost at the end of a film (in iTunes) and the PC froze completely and i had to force a restart.
Ive looked at the event viewer, and there 2 errors, 1 critical, and 2 warnings at the time the PC froze, but i dont know how to interpret the details which go with them
Can somebody please look at them and give a view on what they mean?
CHEERS!
Maybe i should put a copy of them up, but which one do you need?
CHEERS!
