system develpment question: webcams and servers
19 Oct 2002
hi peeps :)
a client of mine would like the ability to log into a subtle part of his website and see what is happening at any given time in his factory, so obviously the best way is a webcam/server solution...
basically, i have never done anything like this what would be involved?
• equipement?
• code? i'm thinking some simple asp stuff is good enought to get this going?
• security? ssl stuff?
basically just after a bit of advice on setting up a remote webcam system :)
You can by IP cameras that will plug straight into the network. Most of them have a handy web interface that you could use to view the camera.
