Hey guys! I opened the thread here because I'm not really sure what the problem is about, sorry if it's in a wrong section
I just built a system with:
i5 2500k
ASRock Z68 extreme4 gen3
corsair vengeance black 2x4gb
asus 560ti
ocz zs series 750w
2.5" 250gb wd caviar black (the laptop one)
Thermaltake Armor case
The problem is that it won't start. I built the system today and in the first tries it booted normal in the bios menu, stable voltages etc. I tried to install Windows with no success as (after creating the space) there was an error message about windows not being able to boot from my hd because I had to enable an option?
After that, I rebooted the system to boot to bios, but the system took about 5-8 seconds to start up after shutting down and it loaded an empty bios interface! I press the restart button, and it shuts down permanently
The PSU switch is on, the standoffs are all ok and the GPU has 2 leds working. I double checked the cables and the connections, I tried to boot from the motherboard's power switch, I tried the clear cmos button (it seemed to work as the GPU leds went off as the button was in) and clear cmos with battery, still nothing.
What do you think should be my next move? Should I hotwire my PSU to see if its working? Any advice welcome, i'm close to desperate with this machine
thanks in advance!
Mike!
i5 2500k
asus 560ti
ocz zs series 750w
thanks in advance!
Mike!
