Hello! I have recently acquired new guts for my system including a new cooler. It runs louder than my old setup (granted the Arctic Freezer 7 Pro is pretty damn quiet) which I thought was due to the new cooler (Titan Fenrir). I tried changing the included fan to a quieter(?) Akasa Apache but the noise levels did not go down.
I investigated with the highest tech equipment I found, ie my ears, and it turns out the system fans are actually causing the noise! It appears that this motherboard does not dynamically throttle back their RPM by default, and I cannot find a way to either in the BIOS or via software.
Does anyone know if it is even possible on this board?
If not can anyone point to what are the absolute quietest 120mm fans at max RPM?
Thank you!
Thank you!
