- 16 Jun 2008
Right, ive had a problem since building my new PC. After automatically going into "Sleep" mode, once woken it freezes, after 10-15 seconds it will allow me to move the mouse cursor and use the PC, but it then freezes again and so on. Nothing obvious in task manager is causing the problem and the only fix is to reboot. Unfortunately, most of the time it freezes during the shutting down stage, so ive had no alternative but to hold the power button.
To prevent this happening i told it never to go into sleep, as i've not had time to figure it out, but last night i put it into sleep, and when i woke this morning it was back on again
It did the usual freezing thing and i noticed abit's UGURU icon flashing in the systray, apon opening i discovered the CPU temp was 82 degrees! I also noticed in task manager that UGURU was also using the CPU more than anything else and a fair amount of memory, which i thought was strange for a pretty small application.
I was able to check the core temps using CoreTemp and it told me they were all around 30-31 degree (which are my normal idle temps). I then shut it down, left it for 20 mins and booted it up, checked the temps and they were all back to normal, UGURU said the CPU was 16 degrees, as did Fan Speed (which i think is driven by UGURU anyway?) and core temps again around 30 degrees. But when i tried to open IE, it then froze again. After restarting it now seems to be ok again.
What is the difference between CPU and Core Temps? Cores are always around 28-32 but the CPU is always around 16-22.
My specs are as follows:
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
Tuniq Tower 120-LFB CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
Samsung SH-S223Q/BEBN 22x DVD±RW SATA Dual Layer Lightscribe ReWriter (Black) - OEM
Antec Nine Hundred Ultimate Gaming Case
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - OEM
Arctic Silver 5 Thermal Compound (3.5g)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
Seagate Barracuda 7200.11 500GB SATA-II 32MB Cache - OEM (ST3500320AS)
G.Skill 4GB DDR2 PQ PC2-6400C5 (2x2GB) CAS5 Dual Channel Kit (F2-6400CL5D-4GBPQ)
Powercolor ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (66I-01939)
Nothing has been overclocked other than the graphics card using CCC, but it was doing this before i modified the settings and before i upgraded the latest version of its drivers and CCC.
Has anyone experienced anything like this before? Im getting alittle worried because of the CPU temp, especially as the fan speed was at 1920 rpm (the fastest it can spin). How can it get this hot when the load was under 20%?
Any suggestions would be greatly appreciated. I was hoping to start overclocking soon, but until im sure this isnt hardware related i dont really want to try my luck.
Thanks!
It did the usual freezing thing and i noticed abit's UGURU icon flashing in the systray, apon opening i discovered the CPU temp was 82 degrees! I also noticed in task manager that UGURU was also using the CPU more than anything else and a fair amount of memory, which i thought was strange for a pretty small application.I was able to check the core temps using CoreTemp and it told me they were all around 30-31 degree (which are my normal idle temps). I then shut it down, left it for 20 mins and booted it up, checked the temps and they were all back to normal, UGURU said the CPU was 16 degrees, as did Fan Speed (which i think is driven by UGURU anyway?) and core temps again around 30 degrees. But when i tried to open IE, it then froze again. After restarting it now seems to be ok again.
Thanks!
