I have an Asus A8N-SLI Premium mobo with the 1009 BIOS, an X2 3800+ CPU, 2x1GB Mushkin XP4000 black RAM.
After buying this rig before Christmas I had a stable overclock of 2500MHz. HTT x3, CPU at 250MHz 1.5V, RAM at 1:1 3-4-3-8, 2.8V. It ran Prime95 stable on both cores for more than 48 hours when I was setting it up. Up until March it was rock steady with whatever I threw at it.
Recently however I've been plagued by an odd behaviour that I would describe as paralysis. At random times after a few days of running, not just under heavy load either, my system would start to become unresponsive. Processes would still run fine until I tried to interact with them. For example, I was watching a DVD on my secondary display using ZoomPlayer and I noticed my apps on the primary display had frozen. The DVD continued to play fine until the film finished, at which point I tried to close ZoomPlayer. It had frozen like everything else. I could still move the mouse pointer and if I had multiple apps visible some would look OK until I try clicking on them, at which point they freeze too.
CPU usage was at 0% for both cores and the mouse could still be moved but everything was frozen, no disk or network activity. I could even press CTRL-ALT-DEL and all apps would disappear like it usually does before the window pops up with the Task Manager, Logoff, Shutdown and other buttons. However that window would never appear [left it over an hour waiting!]
At first I thought it must be a low-level driver as the PC was not completely frozen, the CPU was running cool [front panel] so it can't have been a standard rogue process. I uninstalled any software that had installed a low-level driver, including Daemon Tools, Diskeeper, PGP Desktop, Soundcard [Hitec Mystique DDL 7.1]. Almost everything except the Firewall as I considered running without it too risky.
Most of this was done with my overclock disabled, the BIOS settings set back to the defaults because I wasn't sure if that might be the cause. The problems still keep arising so now I'm thinking the CPU is damaged. I can't imagine RAM damage would make it behave this way with BSODs all over the place.
Has anyone else experienced this weird kind of 'paralysis' on their PC? I'm at a loss to know what to do next, besides risk buying a new CPU.
