System HDD is not the same as the W7 installation HDD
Permabanned
26 Jun 2010
As you can see the System partition is on a different HDD from the Windows7 installation.
Does anyone have any idea why?
Also I seem to be having some performance issues on a clean install and wondered if this could be the problem and how to fix it, preferably without formatting and starting again.
Thanks.
there should be a 'system reserved' partition of about 100mb. I assume you told windows not to do this when you installed?
My first thought is that in the BIOS, disk 2 is set at the highest priority, and thus when Windows 7 is installed, it sees this as the system disk, even if the actual Windows installation is on another drive. My D: drive is the system disk in my PC even though Windows 7 is installed on C:.
I think the theory is that having the system partition on a separate physical drive might improve performance in some tiny way. I've found the only reliable way to avoid it being on a separate drive is to unplug all storage drives during installation. Not looked into it too much but iirc your system might not boot if you subsequently remove the drive that holds the System partition
I have just changed the boot priority in the BIOS and you are correct, it seems the D: drive has the Boot-mgr and is the first bootable drive, yet the W7 installation itself is on the C: drive.
When I changed the priority so that the C: drive booted first, it wouldn't boot. When I returned the D: drive to boot first then it is fine.
Why would W7 install in this way, and does it have any impact on performance in a negative way, other than not being able to remove the D: drive without rebuilding the boot mgr of course.
What you can do to fix it..
Unplug all other hard drives
Turn pc on and insert W7 dvd
Set it to 'repair startup'
Yes it won't boot if you change the priority of or remove the system disk. It isn't Windows that has installed this way, it's simply a combination of BIOS settings and where you chose to install Windows that's the problem. It doesn't effect performance it simply means if anything happens to the system disk, Windows 7 won't be bootable (although you can probably fix this by running startup repair from the installation DVD).
