Anybody done this and had any issues? I have a laptop here that is refusing to boot due to:
Anybody actually done this on an OEM and have any input at all please?
Now while hopefully a CHKDSK may fix it and all will be good I was looking up the proceedure for recovering the system from the hive back up files and came accross this warning from MS:Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Which leaves me with funtimeWarning Do not use the procedure that is described in this article if your computer has an OEM-installed operating system. The system hive on OEM installations creates passwords and user accounts that did not exist previously. If you use the procedure that is described in this article, you may not be able to log back into the recovery console to restore the original registry hives.
