- 11 May 2007
My system has been going slow then speeding up a for some time. I though it was spyware or a dodgy MS patch or something like that but now I think it's heat related.
The PC really is pumping out some heat, but I don't know which bit is going wrong and not sure if any of this stuff has heat sensors. It's a medion system not a home build.
I turned on Smart HDD in the bios and installed HDD temperature and it reports the HDD a seagate 120GB ST3120023A as runnig at 49degrees, is this normal? for a 7200 rpm drive?
I put a second drive into the machine 2 days ago, which I have now removed. the machine started going slow even though the CPU performance in task manager was like 10-20% or less which I couldn't understand at first.
The drive must have tipped it over the heat threshold as I started to get graphics corruption and tonight I noticed only one of my ram sticks was not being reported so it looks like heat was causing thing to start to give out.
Need some advice on how to sort this out. I assume the extra heat could be from the cpu, hard disk or faulty power supply but which? Any software I could try to see if the board has sensors?
System is socket 478 2.6 P4
Seagate 120GB ST3120023A
Medion Radeon 9600TX graphics card (MSI Ms-8906)
Medion MD5000 (msi-6701) SIS 648,963
2x512MB DDR333
16Xdvdrom
16xwriter
Nothing is overclocked and overheating happens while surfing or doing something just as untaxing.
Anything I can check?
Thanks
2x512MB DDR333
16Xdvdrom
16xwriter
Thanks
