Compaq Presario SR1909UK Desktop
AMD 64+ 3500 Processor
ASUS A8M2N-LA Motherboard
4gb RAM
7900GC graphics card
Been having some trouble a while now, system re-starting when selecting a particular user on Windows start-up and then not starting up at for a while.
But more recently its been dog slow, the hard disk is working continually and easy task such as opening windows are taking an age, so I checked a few things.
First up I notice that Windows is only seeing 1GB of 4GB
So I decide to have a look inside and re-seat the memory.
On doing so it then doesn't go past the first Compaq DO screen (F1, F10 etc...) - and no F keys work.
After an hour of re-connecting things to the motherboard I say "****-it" put it all back together, stand it upright and the thing starts-up!!!!!!
I'm thinking some sort of Motherboard problem here - dry-joint...???
A few times recently after putting a new power supply in (the problems were happening before this) its still not been starting up properly but again a 'jolt' to the case has fixed it.
I've checked the bios and it says 4 sticks of ram are present, CPU-Z says the same, but I don't know how to check whether they are actually being used though!
Compaqs own help says in the system info bit that 4GB is there too.
But the Task manager disagrees:
Some background info too... A while ago my daughter clobbered a usb memory stick whilst it was still in causing system freezing - un-plugging the front usb section from the motherboard solved this.
I'm going to try clearing the CMOS when I get home tonight and see if that does anything. The BIOS was updated a few days ago too.
I know its case of virtually anything could be the cause, but I post in hope..!
4gb RAM
