system not starting up ok
7 Nov 2004
Southampton/Oxford
ok my old ancient system as u can see on my sig, well on to the problem, turn it on, goes thru the bios, get the normal beep then when it comes to the windows xp with the blue loading bars moving goes off the screen, it restarts,, now it can go into safemode and works there, no spyware or viruses scanned for them so i don't know what it can be, im guessing its hardware problem, if it is then im just gonna buy a pre built system because i cba to repair tht kak
If it works fine in safemode its probably not a hardware problem. Only way to find out is to reinstall windows.
Why buy prebuilt? Build your own, cheaper and more fun.
