System opinion
30 Sep 2015
London
I want to order the following components:
I have a 23" LG IPS Full HD monitor, peripherals and a mechanical hard drive.
In one month I will add a video card too, probably a 980ti.
The system will be used for gaming, programming and watching movies.
Should I change something or the components are good enough?
Looks good to me but I would chuck in a better SSD as the BX's are slower. However, if that doesn't matter it's a nice looking build.
Are you set on that case? Maybe a little 'bling' to be included? White RAM, cable extensions ;)
I can go for another SSD. I just want to use it for OS and other apps. I don't think I will run any games from the SSD.
I'm not set on the case either but it looks nice and got good reviews too. I can go for a different case if it's worth it and close to that price range.
I'm without a computer since May so I want to get something going as soon as possible :)
I would recommend to get i5 6600k as in the future you may overclock it. It £20 more but it gives you a option in the future to increase performance. Everything else looks good
I've placed the order on Friday. Tomorrow or on Tuesday I'll have the components. Yay! I even got 2x8 Gb ram. Got a pretty good deal.
Now in one month I want to get a video card and I'm set.
Cheers!
