system over heating!
23 Mar 2007
Essex
hi everyone my system has decided to hit the roof with its temps and i no what the cause of it is, its full of dust so i have just ordered myself a can of compressed air but i dont feel its enough i had a usb mini vacuem and to be honest they are rubbish dont suck up anything at all. i was wondering if someone could tell me where i could buy a small battery powered vacuem or something that would suck the air up inside.
cheers
You need two things.
(1) a regular vacuum cleaner. Henry are the best for this sort of thing.
(2) A soft paint brush. Best would be a woman's blusher brush.
Directions:
Brush the dust away, and hover it up with the hoover. For the dust on the motherboard, use your air duster to dislodge, then hoover it away.
As above ^, + avoid nylon and use a natural bristled brush.
If it's very severe, you may be better off stripping it down and doing each bit in detail.
