System Problem faulty GFX Card?
30 Nov 2005
London
All,
I have a serious problem with my PC. I believe it is the graphics card. The problem has arisen today.
My bro was playing a game when the PC froze and displayed a blue screen (he didnt note down the details).
Since then the PC will not boot into Windows, it gets as far as the green sliders (loading screen) then the desktop but only for a few seconds. A bluescreen appeared when I tried to get into Windows it stated nvlddmkm.sys error.
The PC can boot into safe mode and low resolution mode fine. I have uninstalled and reinstalled the latest drivers but it does not fix the problem.
It did work briefly for a few minutes with a fresh install of the drivers but when I tested the system with a Counter Strike Source stress test the PC froze and displayed a blank black screen.
The graphics card is a 768Mb XFX 8800GTX XXX PCIE.
Any ideas what to do?
Afraid not.
I'm running MemTest and no errors so far.
I had a few artifacts on screen when I tried to boot into normal Windows again before it froze and a black screen.
Seems to be pointing towards the GFX Card don't you think?
Ran memtest no issues.
I've only seen the nvlddmkm.sys bluescreen error once.
The rest of the time it's just been a frozen blank black screen.
The problem happened before the new drivers were installed, I installed the new ones to see if that would fix the problem. Plus I did run driversweeper anyway.
Thanks for the advice guys.
What I don't understand is that in safe mode and low resolution mode everything works fine.
But as soon as I load into normal Windows Vista it freezes after a few seconds on the desktop to a blank black screen.
Temps are fine running nice and cool, cooler than I realised :)
I've emailed the supplier were I got the kit from so I'll see what they say.
Just tried the PC, now get funny characters on screen during boot and blue lines on the screen.
Looks like the gfx card is borked, going to buy a cheap gfx card on the highstreet and test it on my system.
