Hi all,
looking for some advice on refreshing my rig. It's more or less gaming exclusive. Current set up is as follows:
Crosshair 3 formula
Phenom II X4 955BE @3.8
8GB DDR3 1333mhz
GTX 590.
I got the 590 dirt cheap from a friend which is why it's so GPU heavy, had a pair of 5770's before which worked really well. I want to update the CPU and mobo to get as much out of it as possible. So far I've looked at getting the Asrock Z87 Extreme6 with an i5 4670k Haswell chip and some beefier DDR3 to go with it.
Any thoughts or recommendations on putting that lot together?
Thanks!
Crosshair 3 formula
8GB DDR3 1333mhz
GTX 590.
Thanks!
