Those are recommended specs for maxing out the game visuals at high resolution. Besides, it hasn't correctly detected that you're running Crossfire so ignore that checker.
You should be able to run it fine. I get over 100fps @1080p on my 5770. Although it has its own issues with strange stutters and uncommon artefacting sometimes. edit: on low doh
I'd say you could run it on high settings with above 30fps.
I've found BF3 to be mostly CPU dependent rather than GPU. When I had a Phenom II X2 555 BE and a 6950 running Battlefield, I would run it on low and not even reach above 30fps while in multiplayer. With a 2500k and 6950 I can now run it at high/ultra no problem.
Medium textures and no /little AA at very respectable frames I reckon. If you can live with dips below 45FPS maybe high. Ambient occlusion, AA and texture levels really dent performance. TBH BF3 looks OKish on low
