- 4 Nov 2011
- N.I
Hi,
Built my system (in sig) in December last year, not an issue since day 1. Temps and performance are great and system has been 100% reliable. CPU is currently at stock and GPU is not oc'd. Over the last week my system has been misbehaving. Had a few occasions where the fans spin up to what sounds like full and i lose connection to the monitor requiring holding down the power button to get it to switch off. Only happens under GPU load. Tonight i reseated the GPU and installed latest drivers. Now instead of spinning up the fans and losing connection to the monitor, it simply restarts the system when its under load (can happen immediately or 10 mins into a game). Temps are not an issue. Under heaven benchmark it does the same thing. Have stress tested the 9900K thoroughly tonight and it is fine. Only putting the RTX under load creates the issue. I am virtually positive the RTX itself is fine. I suspect PSU (ocz Modular 1000W... must be 7 years old by now). Anything else i should investigate before i throw some money at a new PSU?
