I've been having problems with my system
ASUS P5B Deluxe WiFi
Intel C2D 2.4Ghz - Artic Cooling Freezer HSF
4GBytes Geil PC2-6400 RAM
BFG 8800GTX
2 x 150 Gbyte Raptor Boot Drives in Raid 0 - XP/games installed here
3 x 250 Gbyte Data Drive in Raid 5 - Data/Pagefile on this drive
SB XFi Gaming Edition
Tagab 800W PSU
Antec 900 Gaming Case
Scythe Fan Controller/Monitor
Memory set in BIOS as Geil Spec 4-4-4-12 2.1V and speed set to DDR2-800
Everything else as auto or default
When I built the machine I used an anti static wriststrap to avoid static problems.
Originally had problems with 4gbytes of RAM flashed BIOS to latest version, wouldn't boot so dropped RAM out and found a dodgy RAM chip.
System didn't seem stable (BSOD under Vista Ultimate 32) which prompted the BIOS update. Vista install became so corrupt that I had to reinstall anyway and needed a 64bit OS to fully use the RAM.
Fully patched windows, all the latest approved drivers, no devices missing or in conflict.
Patched all the games COD2, MoH, DOOM3 to the latest available, still they crash.
Thought I'd try running Orthos to see if I had a stable system as this is what the overclockers use to test their systems for stability so I thought that it would finally tell me if there was a problem or not, i.e. if it ran for 6 hours it was probably stable and I should look at the games I am running that crash.
Orthos blend test crashes after 16 seconds.
Any ideas or is this just down to dodgy hardware?
Thanks in advance for any help.
BFG 8800GTX
Tagab 800W PSU
