- 30 Dec 2004
- Bromley, Kent
Hi all,
I need some assistance in getting my new system stable, although its a weird one.
Spec:
Q9550
DFI JR P-45 T2RS
4 x 2GB Corsair 6400 RAM
HX620
2 x WD 640GB Caviar Black
4870 1GB
Vista x64 HP
Temps are all fine, no problems there and I can run Prime etc. for hours, no problems. But when I boot up or restart it SOMETIMES either blue screens at Windows or before or has an issue with a file becomming corrupt.
- All drivers, firmware and BIOS are up to date
- System is prime stable
- Everything is plugged in and checked
- WD tools say that the HDDs are fine
- Re-installed Windows (didnt have a choice on this one alas...)
- When in Windows its pretty much fine.
- HDDs are running on AHCI
- Memcheck shows no errors
Now I think this might be down to a BIOS settings issue, butthe trouble is, I don't quite get each of the settings in the BIOS for recommended RAM timings and voltage settings (although this would be odd as its fine when in Windows)
Anybody got any help or advice?
Thanks
- Pea0n
Spec:
Q9550
DFI JR P-45 T2RS
HX620
4870 1GB
Vista x64 HP
Thanks
- Pea0n
