system temp too high?
23 Jun 2009
just wondering i the following temps are too high as i have seen people with the same cpu and fan with lower ones (all idle):
case, lian li b25
i7 920 with akasa 967 and artic 5 thermal paste: 37 c
"System", gigabyte ud3r: 51 c.
any help would be greatly appreciated
oh yeah, the hsf is faceing the exhaust fan, would have thought that this would be right as its pushing the heat out of the system?
i am using easy tune 6 which came with the motherboard, what would you reccomend?
no idea what the temperature of the room is i am afraid. how muvh above room temp should it be would you say, or does it vary a lot?
complete newbie lol
memory voltage in bios says 1.5v,cpu 1.2v in bios but 0.912 in ET6. cpuz says the same.
thanks for your reply
