my full system is below.i have the 3 120mm fans running that came with the case.should i upgrade the cpu fan though cause im using the one that came with the processor.my temps are below all idle.
my graphics card idle is 53c
mainboard 32c .
cpu1 43.0c.
cpu1 core 28.0c
cpu0core 28.0c
HDD temp 40.0c
is this ok temps or should i get some extra cooling in there
Antec Case P182
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Western Digital Caviar 400GB 7200RPM S300 16MB
Corsair Memory 520 Watt, ATX, EPS12V, PS/2, Modular Power Supply
Sapphire ATI Radeon HD 2900 Pro SILENT Heatpipe 512MB GDDR3 VIVO TV-Out/Dual DVI (PCI-Express)
mainboard 32c .
cpu1 43.0c.
cpu1 core 28.0c
cpu0core 28.0c
HDD temp 40.0c
Antec Case P182
