You think these are cause for concern?
I've only had the system for approx 2 days, i thought the idle temps looked a little hot so i decided to run Team Fortress 2 for about 40mins ( maxed out the settings as much as possible ) and after about an hour came out and checked. Which is what the above is.
Obviously im asking if its a cause for concern so i can contact OcUK sooner rather than later, but im not sure what the exact thermal threshold of the Q6600 is.
Not sure if the HDD temp sensor is broke or not but it seems to hardly move XD the GPU temp is interesting, it only seems to raise 8*c from idle when its doing something. I can only imagine that the 4870 isnt helping things, cooking at 80*c constantly, but what can you do... Well you can sell it and get a Geforce 260, but i meant other than that.
