System tray icons not coming up
1 Jul 2007
Various
Whenever I install an antivirus program on XP SP3, half of my system try icons disappear, including my volume settings and battery meter. I've tried it with Avast, Antivir, Kaspersky and AVG (which I'm using currently) and they all give me the same problems. Any ideas?
Goto My Network Places... Under Network Tasks there is an option to show or hide UPnP devides. Try turning this off if it is on. I had this problem before and this turned out to be my issue.
TrUz
By off do you mean that it should be showing or hiding the icons?
EDIT: You're a genius, all working :D
