System trouble
28 May 2007
Saturn’s moon Titan
tonite my pc started acting strangely. It done a few updates had a few games of doom enteral in between then after the updates. I started getting multiple errors last one was machine check exception. Can’t believe this even tried my old 2080ti in the pc same problem could this be a power supply problem?.
Could a dying nvme do this I can’t get into windows for a couple of seconds then a blue screen then reboot just does this now.
Update after swapping out graphics cards 3 of them ) swapped psu out tried to install on to different storage during windows 10 install it quickly blue screens with a unhappy face then reboots.
It goes that fast it’s hard to tell .irq notless equal .machine check exception watchdog something to name a few .
With those sort of errors i would be looking at CPU overclock or memory issues. If you are getting errors trying to do a fresh install that is where i would be looking.
Save a profile with those settings and then set CPU and memory to stock (No XMP) and then see if you are still getting the same issues. If the problem still persists then i would run memtest bootable and see if you have got errors. If you have then i would say the memory was faulty. If you are not getting the issues at stock then first set the memory settings and retest if there is an issue. If all ok then it might be down to the overclock.
Is it worth trying Win 10 recovery to last restore point before you did upgrades?
I’ve tried everything I no but I have set up a rma for the bundle thank you for all reply’s .
Regards scubes.
Sorry mate I don’t no anything about pcs that’s why I always get these bundles no adjusting any settings just plug and go.
Thank you mate just have to package t up and get it collected tomorrow thank you all for your suggestions really appreciated.
