Hi all,
Great forum, already gained a signifiant level of knowledge from previous posts but would like your help and comments on my specific upgrade.
Presently running:
Athlon XP 3000+ (2.15gz)
768MB RAM
Maxtor 120GB HD 6Y120P0
Radeon 9800 Pro
SB Audigy 2 (5.1)
450w PSU
System is getting to a point as I am sure you will agree where it is stuggling to run new games so it's time for an upgrade (particularly as COD4 is on its way...). As I have a laptop as well, I use my desktop pretty much for games and music only. From my original build, I am guessing I can re-use the soundcard, possibly the HD (?), and the case which is a Thermaltake Xaser II.
I was hoping of getting the rest for something in the region of £600. However if I go for the 8800GTS, guess I am looking at a bit more? I did once buy a graphics card for £350 (GForce 2!) and said after that experience that I would sooner buy a mid range GFX and upgrade after 1-2 years rather than 1 top end one and hope I'll get 3 years out of it? Any thoughts. Or is the 8800 just worth the money? Anyway, would appreciate your thoughts on a good system to give me a good 3 years futureproof.
I was thinking:
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail
Asus P5K3 Deluxe WiFi Intel P35 (Socket 775) PCI-Express DDR3 Motherboard
OCZ 2GB (2 x 1GB) PC2-8500 1066MHz SLI-Ready Edition Dual Channel DDR2
GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
Samsung SpinPoint S 250GB SATA-II 8MB Cache - OEM (HD250HJ) - if needed
Thoughts? Already at £700 with this build mind you?
Oh yeah, also have the Zalman Flower CPU cooler in my present system - is this still good enough or does this need upgrading?
Thanks all.
Presently running:
768MB RAM
Radeon 9800 Pro
SB Audigy 2 (5.1)
450w PSU
I was thinking:
Thanks all.
