System upgrade - budget of ~£350
29 Dec 2003
Newcastle upon Tyne
Hi GH,
I'm wanting to upgrade my system which I use mainly for gaming (BF4 & PS2) and also as a home lab (VM's, GNS). My current spec is:
i5-2500K (SB, LGA1155) - Overclocked to 4.6GHz
ASRock Extreme4 Gen3 (Z68, supports some IB processors - full list here: http://bit.ly/19UF4Aq, supports memory speeds 2133(OC), 1866(OC), 1600, 1333, 1066)
Corsair XMS3 DDR3 1600MHz (2x4GB)
MSI GeForce GTX 570 OC Twin FrozR III PE (1.2GB)
Asus Xonar DX 7.1 PCI-Express
Antec TruePower Modular 750W PSU
Samsung 830 SSD (128GB)
Seagate Constellation ES 2.5" HDD (500GB)
NZXT Phantom (1st edition)
Waterblock: EK Supreme HF (1st edition)
Res/Pump: EK DCP 4.0 Combo
Rad: XSPC EX240
The stuff I have put in bold are what I'm expecting I'll need to upgrade, the rest I'm happy to keep and reuse. I'll sort out a new WC block if necessary :)
I'm happy to switch to AMD if it's any more cost effective and I have no preference on GPU manufacturer - whatever gives me the best bang for my buck at the moment!
Thanks for looking, all suggestions are greatly appreciated.
Kona*
Tbh that build is pretty decent, you won't get much of a performance boost from going from the 2nd gen i5 to say a 4th gen i5 - I'd keep that CPU and motherboard. Maybe sell that GTX 570 of yours and maybe buy a GTX 780
I thought the 4th Gen i5's were much, much faster - thanks for putting me right! I'm glad to here it's still a decent enough build, I'm not finding it slow usually, it's just BF4/PS2 are taxing it quite a lot! Plus VM's love memory :)
I'll check out both the 270X and 780 - the memory is a steal at £129!
