Hello guys (n gals)
This is another am I doing the right thing post.
Current set up
i7 920 ( bloomfield ) @ 3.6ghz on air cooling (Noctua)
Asus P6T SE Mobo
Gigabyte Windforce HD7950 3gb DDR5
12gb triple channel RAM (3 x 4gb)
120gb SSD for OS
1TB HDD for everything else
CPU was bought and OC'd from launch
Upgraded the PSU,GPU and SSD January 2013
I use the system mainly for games, but also a little for 3dsmax and Adobe premier pro and after effects.. but gaming is the important thing.
I was considering the following-
i7 4790k (Devils canyon)
Asus z9z - k
Vengence pro 16gb dual channel ( 2 x 8gb )
and reusing everything else...
So, you think its worth it? itll be around £500.. I keep reading other posts all over the web some saying its not worth it and some saying the opposite. I dont tend to upgrade often maybe once every 2 or 3 years for various parts.. but never a whole new system at once.
Games are okay on my current system but some that i play the most ( arma 2 / 3 mods ) are really choppy in cities, im also wanting to play star citizen once its finished.
Is it worth waiting the next lot of cpu's with pci-e3 and DDR4?
Any advice would be useful!
Thanks
Current set up
Asus P6T SE Mobo
120gb SSD for OS
Asus z9z - k
Thanks
