System Upgrade
15 Oct 2011
Hi All,
I posted a few months ago about possibly upgrading and was advised to go for a new monitor which has been fantastic.
I'm now wanting to upgrade the components as I'm having issues with FPS on some games. Also thinking of the future to.
PSU: XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £45.82 1
CASE: Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW)
RAM: GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL38GB1600C9DC)
MOBO: Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
GPU: Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card
CPU: Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor
My CPU is overclocked to 4.1ghz so that seems fine to me. I have 2 SSD's so don't need a hard drive.
Just so you have an idea on budget I'm thinking of a GTX 980 GPU? Any other suggestions?
cheers,
ARMA 3 is CPU intensive which is why you're having issues, the GPU isn't going to make a difference. Buy a 3770k or just change the settings.
Really wouldn't bother changing the 3570k for the 3770k tbh for ARMA 3.
I have a 4970k and would get slightly better FPS in ARMA 3 if I disabled HT..
ARMA 3 favours Nvidia over AMD so Nvidia would be the way to go.
I have a 4790k @ 4.5GHz and a GTX 980 - average 70fps max settings 1920x1080, 3k view distance on a 60/60 decent server. Of course that'll dip to 50fps if I go inside a city. I don't play on crap servers either so I'm not limiting my performance because of the server I'm on.
Also, if you overclocked from 4.1 to 4.4 you'd see a decent increase in performance. I'm not familiar with i5 -3570k overclocking, but I imagine 4.4 is a reasonable goal.
