System will not work, please help !
18 Oct 2002
Nottingham
Hello,
Just built a system and i carnt get it to boot up.
Specs
Abit IC7 socket 478 (was working fine in another system 2 weeks ago)
P4 1.6 400FSB (just got this delivered from ebay today)
512Mb PC2100 RAM (brand new from internet)
Radeon 8500 64Mb AGP (been in box for about 3 years)
I have power going to the system, all fans spinning etc
I get no picture on monitor, just the test screen on monitor 3 different colours.
The system makes no beeps, with or with out the PC speaker connected.
I have cleared the BIOS.
Anything else i should try ?
Thanks Ben
I just had same issue, fans spinning etc etc no video nada...after trying all the bits in another pc, they all worked fine..
Eventually, I hooked the PSU from one pc to my IC7 and it worked fine...
Thus, it boiled down to my PSU.
Seems one of the rails proably broke. Ordered a new PSU and its all running fine..
Check that you have connected all the PSU sockets in the mobo, you may notice that you are missing to plug a 4pin bit (near processor?)
# No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
Fished this up from a place I don't believe I'm allowed to link to.
-Leezer-
yeah that square 4 pin one is Very important.....
I fixed this awhile ago :p check my first date of post.
I had brought the wrong type of CPU, i had a P4 willimate and it needed to be a northwood.
